주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
The BLU Life 8 is a smartphone based on Android 4.2. It is equipped with a 5" display with 720 x 1280 pixels resolution.
41 질문 전체 보기
All data files have stopped working how to fix this issue
Keep shutting down unable to make calls
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Didn't work for me. Won't even go to home menu. It comes up saying unfortunely app has stopped. Won't let me hit anything
의견 추가하세요
SKIP THE UPGRADE
Save by fixing with an all-in-one kit.
Shop iPhone Fix Kits
SKIP THE UPGRADE
답변 2개
Bring your phone into a local phone repair shop, they will be able to take your phone apart and find a solution to your problem.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
Try a factory reset.. if you don't care about ur data in the phone.
Instructions
1. Power off the device. If unable to power off, remove wait som seconds and reinsert the battery.
2. Hold the Volume Down Key + Power key for 15 seconds and then release.
3. Press the Volume down key 3 times to select Delete all user data by pressing the power key.
4. Scroll down to and select Yes - delete all user data. use power key to comfirm
5. The device will reboot and display the recovery screen.
6. Select Reboot system to restart the phone
Good luck with that
해당 답변은 도움이 되었습니까?
점수 0
댓글:
This didn't work for me. When it finally starts up before home screen it comes on and say unfortunely this app is not working. Doesn't even go to home screen. Won't do anything. U can hit report or ok and nothing works
read the above instruction for a factory reset... u dont have to power the device in normal boot ... read vividly above... to restore the phone factory setting.. (all data will be lost)
의견 추가하세요
귀하의 답변을 추가하십시오
shirdan38 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 78
