Why are the pictures I take blurry?
The pictures I take with my cameras on my Lenovo A8 are coming out blurry? Why?
좋은 질문 입니까?
좋은 질문 입니까?
It is possible that the protective coating from the factory is still present on the lens, or the lens is simply dirty. First, try cleaning the lens with a clean cloth, dampened slightly with water or rubbing alcohol. If that doesn't work, the camera may be unable to focus properly, or is otherwise damaged. Also, note that the front-facing camera has much lower resolution compared to the rear-facing camera (2 megapixels versus 5 megapixels).
If you decide to try replacing either camera, there are iFixit replacement guides available here:
Rear-Facing Camera Replacement
Front-Facing Camera Replacement
It is a very easy fix, and replacement parts are readily available online. Good luck!
안내서
난이도:
쉬움
8 minutes
안내서
난이도:
쉬움
10 minutes
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 652
