주요 콘텐츠로 건너뛰기
4th Generation Apple AirPort Extreme Base Station (Model Number A1354)
18 질문 전체 보기
How to change country code?
Hello
I have a MC340LL/A model and have to use it in Europe
airport utility in the option network show only US and america country ...how to correct this in order to respect local legislation as the AEBS is supposed to be compliant to world regions regulations ?
Thanks for any hints
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Hey @Philippe P, did you solve this problem of change firmware region on Apple AirPort using the Java solution commented by @mayer ?
I saw the specifications of the Java software, and I believe this program only helps to access the equipment without the AirPort Utility, with no advance (plus) settings, like change the network country firmware (region).
Best regards!
댓글 달기
답변 2개
선택된 답변
Here's a Java-based configurator for the Apple AirPort Base Station and Lucent RG-1000 wireless access points. It should run on any platform with a Java 1.2-compliant runtime environment installed, permitting the configuration of a base station from any host.
http://gicl.cs.drexel.edu/people/sevy/ai...
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
댓글 달기
This is a firmware-based setting that I don't believe you can change; it's a fairly common request but I've never seen a solution.
See e.g.:
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Philippe P 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 13,196
