주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
질문 마감됨
I do I need to replace my phone's LCD?
Hi all,
My phone screen randomly started doing this the other day (although it had been dropped a few hours before that). As you can see, half the screen has a grey tint, and sort of artifacts begin developing after 30 secs.
My question is this: do I need to buy a new lcd, or is it worth cleaning and reseating the cables for my current one?
Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
Since you did say it was dropped before your screen started to act up i would say that now your screen is on its way out. Which means that pretty soon it will eventually black out or wont work at all so yes you should get your screen fixed as soon as you can
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
If you open that and reconnect the connected. It may be fine.
Worth to try
Luck
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hey everyone, just an update here:
It started to gradually worse, as Justis warned, so I ordered a new lcd and that's solved the problem. The old lcd had a big bend in it under the grey part, so I guess that's what caused the damage. For anyone else with a similar problem, you have a warped lcd which will have to be replaced!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 70
