Power Button not working after I replaced Power Flex
I replaced Power Flex Cable. Everything is connected and its all in one piece with zero rips. The Volume buttons and mute are working correctly. The headphone jack is working correctly. The connectors look great all intact. The only way I can get it to power off is by disconnecting battery. I can power it on by plugging it in and everything is functional except the power button. The power button clicks and feels normal. Any advice? Could a hard reset work?
좋은 질문 입니까?
댓글 1개
Seems like a pattern with this system of cables at the top of the iPad. (iPad2) Replaced digitizer and while releasing the motherboard all but the cable to out of the motherboard to the top cable system to plug in the WiFi antenna, lost function in the wake/sleep (power) button and mute. Replaced that assembly because of a nick, and lost all function whereas the up/down volume at least worked before.
Terry Wright 의
