주요 콘텐츠로 건너뛰기
Fix Your Stuff
Right to Repair
Parts & Tools
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
678 질문 전체 보기
Trackpad/Keyboard wont work, minimal water damage to hardware
Alrighty so my trackpad and keyboard wont work, it's sort of crazy how this happened because theres obvious water damage, and nothing ever spilled on my laptop! The apple store confirmed my theory as well. If you familiar with the guts of the newest macbook pro, the logic board is separate from the chip in question. The water damaged circuit board is located center and bottom below the battery. The apple store has a flat rate to fix any hardware issue of 750 dollars which seems absolutely ridiculous. Im using the laptop right now with USB peripherals. I believe now after some research that the circuit board in question is the back side of the track pad. would this make the keyboard not work as well? is the keyboard "hardware" located in the logic board? I really hope not. The apple store guy said that i would need a whole lower case replacement (battery, keyboard, track pad, etc.) but I refuse to believe this. Also would anyone recommend fixing this myself? if I can narrow out what could/should need replacing it will save me a lot of money and frustration. Also I might add that the force touch track pad isn't working properly is a mechanical sense. Its not clicking and feels gummy like a rocks under it or something. Thanks for your time guys!
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
선택된 해법
I've fixed this a couple of times. Hook it up to another Mac in Target Mode. Save your data then reformat the drive. Now do an internet install. See if the problem has resolved itself. I know this sounds simple but it probably took me 40 hours to figure it out. If it works and saves you $750, you know what to do.
UPDATE 11/17/16
Here's MY original question and resolution on this problem:
Trackpad Does not Function Properly
해당 답변은 도움이 되었습니까?
점수 1
댓글:
I went in and did some spot cleaning of corrosion, and honestly with how many times I've brought an apple device back to life with component cleaner It wasn't bad at all. It makes me think humidity was the only think that got to it. I'm not sure how these new trackpads are put together and why exactly the trackpad isnt clicking though. I will give this a try a little later, can't hurt right? Thanks for your time @mayer
Did mayer's solution resolve your issue?
의견 추가하세요
귀하의 답변을 추가하십시오
Mike Hillenbrand 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,053
