주요 콘텐츠로 건너뛰기
현재 iPod Touch 라인은 6세대까지 출시되었습니다.
2618 질문 전체 보기
Error Code 2009 when I tried to restore it,what does that mean?
I cant get my ipod touch to turn on no matter what i try. When i do the press home button and power button thing it says i need to restore so i hit restore. But then it says a restore cannot be done with an error code 2009. What does that mean and is there any hope of fixing it?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 11
댓글 2개
get it replaced from the apple store
To fix this problem, you also can read this article.
How to Get Rid of iPhone Error 2009
댓글 달기
답변 8개
선택된 답변
Here, you may have the answer to your problem:
http://support.apple.com/kb/ts1275
해당 답변은 도움이 되었습니까?
점수 5
댓글 달기
I fixed the error 2009 on my iPhone 5 by following this amazing guide http://www.unlockboot.com/2015/09/how-to...
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
Thank you, it worked for me.
Lol you just replied to yourself.
And UnlockBoot is his own website....
very cheap website and wrong method
댓글 달기
Got error 2009 so I tried a different sub cable and port and worked for me
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Similar to this, I plugged the cable into the computer directly (instead of an external port where other cables are plugged in) and restarted the computer. Updated the software and all systems go.
댓글 달기
https://support.apple.com/en-us/HT204770
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
uninstall and reinstall itunes, if not solved then clean ure usb socket, its works or me
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
how to clean usb socket?
댓글 달기
I have the same error during the latest firmware update. During the firmware update, it stuck at “connect to itunen/restore “. The service center told me that the mother board got faulty. What? Firmware update cause mother board damage?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
help me,i try idevices restore error 2009
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Just use a different usb port/cable
댓글 달기
My iphone 6s stuck on apple logo
And when i connect it to my pc it show “connect to itunen/restore “ but when i try to restore error2009 occure
Plz
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
told me mother board faulty at 2 shop's
same lmao i was on tiktok with my iphone 7 and it turned off and now when im restoring it it gets stuck in the apple logo ;)
댓글 달기
귀하의 답변을 추가하세요
Stephanie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 29
30일 전: 102
전체 시간: 135,815
