주요 콘텐츠로 건너뛰기
2015년 3월에 발표, 2015년 4월 10일에 출시된 Galaxy S6 Edge는 Samsung의 최신 주력 스마트폰 곡선형-스크린 버전입니다.
233 질문 전체 보기
"Battery Temperature too low" when charging after water damage
Hello, my Galaxy S6 Edge shows "Battery temperature too low" when trying to charge, doesn't matter if USB or inductive. It had contact with water so I think this might be the reason. I checked the temperature with an app and it always shows -20°C. Does somebody know what to do? I have already repaired some other phones but mostly just Display replacement or something like that. Do you think changing the battery would help? I also read that there's a temperature sensor but I can't find any replacement parts for that one.. Thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 14
6 Comments
hi.i have 13 years of hardware experience in cellular industry.just change the charging flex cable or charging pin on it.thats it.
This has also happened to me. I have tried with different cables and have even tried wireless charging but this hasn't helped. I can't take the back off to remove the battery and don't know what to do. Please help!
cable must be changed.wireless will not help untill charging flex cable is changed or disconnected.we are based in goodwood.40 to 60 mins max to fix it.
I changed cables and battery but still same error exist. plz help
Change the IC of your phone. Hope..! It may help you. May be ur phone IC is dead that's the reason your phone is not taking charge and showing error.
1에 댓글 더 나타내기
댓글 달기
답변 9개
선택된 해법
Might want to clean it with 90 proof isopropyl alcohol and a q tip
해당 답변은 도움이 되었습니까?
점수 5
7 Comments:
Does this alwas work if it's just a water damage? For example, if the phones falls into water, and a month later I clean it with isopropyl alcohol?
Well, there aren't any guarantees, when you mix water and electronics. However. Cleaning it with isopropyl alcohol and possibly might have to replace a part or two. Should fix the problem
how? what are you supposed to clean? If I'm not mistaken I'm pretty sure the afaik sensor or whatever is in the battery itself
I changed my usb Port and Battery, After that it wont charge, because Battery is Too cold. I tried 3 different batteries and usb ports. What should i clean ? The 2 cables which connect the usbport with tue Mainboard? Need help!
Ppalfinger there are no guarantees when mixing water with electronics. Eins Albert check your battery with a multimeter. Sounds like you're not getting any answers due to a battery problem. It would be nice if you had a known good one for testing
2에 댓글 더 나타내기
댓글 달기
Put your phone in hard processes and after that when your phone is hot test it again ,if it didn't worked you must replace your battery because water is damaged it :(
Arad_SB
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
This has happened to mine on 2 occasions now. Last time it just started charging again after a couple of weeks this time I tried placing it on top of (not in!!!) my tumble dryer whilst it was switched on so it was warm for about 10 minutes and it seems to have done the trick as it wouldn't charge at all before and now it's working fine.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Replace the charging module. Worked for me.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Mobile falls in water ,now while charging percentage is very low and battery is not full charge may you suggest or recover for this
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
One thing make sure that your Battery temperature is below 2 °C (You Can Check This by Hot Keys on Dial Pad; For Honor it is *#*#2846579#*#*),
 And If It is Then You Have To Remove Your Battery (Do Carefully For Non Removable Ones Using Gum To Stick The Battery To The Base)
You Will Find a Small Board Having Connections in Between +VE and –VE Terminals If They Are Covered With A Yellow Heat Resistant Tape Make Sure To Uncover
Heat Whole Battery under Sunlight or Any Other Heat Source under 50 °C (maybe Use Hair Dryer with Low Setting) Probably For 15 Minutes
Put The Tape Back and Fix It Back to Your Phone (if It Have Any Power in it Make Sure to Turn it On)
Connect The Charger and Check Whether it Charges (make Sure That the Battery Temperature Is Increased above 20 °C)
There You Fixed Your Charging Issue Please Makes Sure You Didn’t Ruined Your Battery Or Phone During Process
Thank you
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Rice Or Slima Gel Works
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
This is gonna sound nuts!! However, Mine did this also. And just by accident I squeezed both sides of the phone firmly while it was plugged up to the charger and it worked!! I try not to let the battery die completely otherwise I'll get the error message again but when I do I just do this again and it works again!!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I just had the same issue. I found out that charging the thing with a low power supply ( USB PC 2.0 port ) helps aswell . The USB- Controller on my device however is pretty much done aswell though…..
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
ppalfinger 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 38
30일 전: 190
전체 시간: 123,459
