주요 콘텐츠로 건너뛰기
MacBook 제품군은 2006년 5월에 처음 소개되었으며 Apple의 가정용 노트북 iBook을 대체하였습니다.
3786 질문 전체 보기
Keyboard connector lock on logic board broke
While changing my hard drive, my hand accidentally touched the keyboard ribbon connector cable on the logic board and the locking mechanism broke. The connector is intact just the locking bar broke off and the laptop is now unable to power up. :( I need help figuring out what to do. I wanna avoid buying a new logic board. and yeah the cable seems fine with no dents or marks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
I suppose you're talking about a unibody MB here. This is a very dire situation indeed. You can try to place the cable in the socket and secure it with tape or similar. Take something that doesn't melt at 60 degree, it can get hot in a laptop.
Good luck!
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
That's what I'd try. Here is a link to a source of the tape Apple uses. +
http://www.uline.com/BL_6407/Kapton-Tape...
댓글 달기
Hi Lexzahir,
Sorry I am late to your repair but am posting this, hopefully to assist others with the same problem.
Im not familiar with Apple products in general, but by your description, it sounds like it may be similar to a connector problem I had on a Sony laptop keyboard connector.
I had snapped off the little plastic tab latch that holds in the keyboard ribbon cable on a laptop, and found an easy way to fix it.
The same problem can occur on may different devices, such as CD players, laptop keyboard connectors, camera ribbon cable connectors, etc.
If you break off this little tab, the ribbon cable is not held in at all, and just falls out of the connector.
On the off chance that you have the same type of problem, check out my YouTube video I had posted last year. Not sure what is wrong with your connector. If it is the same problem, you can easily fix it in a few minutes.
Easy Ribbon Cable Connector Fix, Repair.
https://www.youtube.com/watch?v=bhaeKdUl...
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
looks like your video is no longer available.
The link in the original post seems to have been cut off when it was posted.
After posting this, I can see that it is STILL cut off,
So I'll past the address portion after youtube.com so that it is clear
/watch?v=bhaeKdUltz8
Thanks,
Alex
댓글 달기
귀하의 답변을 추가하세요
lexzahir 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 11
전체 시간: 2,845
