An Android 4.4.2 smartphone released November 1, 2014.
52 질문 전체 보기
People can't hear me when I call them
When I make a phone call people can't hear me but I can hear them my phone is not on mute the only time I can be heard is when I have my headphones on
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 45
댓글:
When will the problem get fixed
의 답변
I have the dame problem
의 답변
The update didn't work for me
의 답변
I have this problem, and this solution doesn't work for me.
의 답변
Same, nothing working to fix this
의 답변
17에 댓글 더 나타내기
의견 추가하세요
아이폰 배터리 수리 키트
Only $29.99
Buy Now
아이폰 배터리 수리 키트
Only $29.99
Buy Now
7개의 답변
선택된 해법
Hi,
If you can be heard when you are using the microphone attached to the earphones but not when you are just using the phone, it points the problem being a faulty or loose internal microphone.
One way of double checking this is to open the Sound Recorder app, record your voice for a few seconds, then play it back. If you hear nothing it definitely points to the microphone.
The microphone is located under the small paperclip sized hole at the underside of the phone. This opening may be blocked. DO NOT try to clear it by inserting anything in there, you may damage the microphone. You could try using a vacuum cleaner and just briefly hold it over the opening (it may remove any blockage) and then see if the microphone is now working. If it still doesn't work, check to see if your warranty is still valid and if so either contact the retailer or the manufacturer (depending on what your warranty states) about getting it repaired etc.
해당 답변은 도움이 되었습니까?
점수 21
댓글:
I have a tablet I have tried everything I can think of
의 답변
Couldn't find answer
의 답변
It is a tablet they can't hear me either way
의 답변
Hi @justmenow
What is the make and model number of your tablet?
의 답변
When I go live nobody can hear me and it makes me up set
의 답변
20에 댓글 더 나타내기
의견 추가하세요
My problem is I cant be heard when i call them using normal call.but they can hear me if i call them using whatsapp call
해당 답변은 도움이 되었습니까?
점수 10
댓글:
I have the same problem with a BLU Galaxy XL
의 답변
Vernee thor plus same thing
의 답변
when I make a call no one can hear me but there can on loud speaker
의 답변
same problem, they can hear me on loud speaker but that's it. Does anyone have a solution?
의 답변
의견 추가하세요
I had the SAME problem with my IPhone SE and all I had to do was restart it!
해당 답변은 도움이 되었습니까?
점수 3
댓글:
So we have to restart it again ? so they could hear me
의 답변
If my wireless speaker is hooked up it only puts out sound not voice.
의 답변
의견 추가하세요
It when I go live my fans can not hear me at all
해당 답변은 도움이 되었습니까?
점수 2
댓글:
I can hear when they call but they can't hear me on my Hisense u972 phone what can I do?
의 답변
Hi @mkhaliphi
Did you try what was said in the Chosen Solution above?
의 답변
I solved it. I had installed the OK GOOGLE option and all was fine unless I had used the speaker at anytime on any call.
So if you look up in settings the OK Google you have option of using it just on search screen or when you are on ANY screen.
Get rid of the any screen part and wahlaaa.
의 답변
Did anyone try this fix of changing the "ok Google" option? Have had no trouble since.
의 답변
Voice has been recording but other person has not been listening me.
의 답변
4에 댓글 더 나타내기
의견 추가하세요
Plse help to solve my prob
#people cant able to hear my voice during calls ,but i can able to hear those voice ....plse help me guyZ
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Turn off your OK Google. I just now fixed mine. Same problem.
의 답변
my iphone 6 does not work at my house the person i am talking to can't hear me but i can hear them but when i drive away from my home then they can hear me why is that
의 답변
의견 추가하세요
If you're using a wireless speaker it puts sound out and will not project your voice and check your Bluetooth settings.Go thru your apps .and restart your phone.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
I can clearly hear the receiver yet he/she cannot hear my voice, I have tried turning off ‘OK google’ but it's still not working. Someone please help a sister. Phone model Tecno W5 lite
해당 답변은 도움이 되었습니까?
점수 0
댓글:
When I call some one my voice didn't reach to them why
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
D'Angelo Scharkley 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 270
지난 7일: 1,793
지난 30일: 7,716
전체 시간: 230,768
