주요 콘텐츠로 건너뛰기
PowerBook G4 Aluminum 노트북 15 인치 화면
320 질문 전체 보기
Laptop won't charge battery
The 1.67 GHz laptop won't charge the battery. The computer will turn on when plugged in but the indicator will show "Battery not charging" I have tried another batttery and charger so I've ruled that out. The only thing I can think of is that the power cable from the board to the battery went bad or got bumped out of place. Any one have any ideas?
Thanks.
JB
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Hi! There's a chance that the cable you mentioned is faulty, but if you're 100% sure the battery you are testing is good, it's likely the DC-in module in the computer that is bad. This piece of hardware controls power-related functions. Here's one for the A1138 PowerBook 15" 1.67GHZ machine (you'll want to verify your model number and look it up in the iFixit parts store to make sure to get the right part):
[연계 제품이 누락 또는 비활성화 됨: IF154-108]
It's not an easy repair, but it's do-able, and there is an iFixit guide to walk you through the process.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Sounds like you need to replace the battery- they get old. How old is it?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I have changed the battery
댓글 달기
귀하의 답변을 추가하세요
jeanb 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 1,082
