My dryer gets warm but not hot enough to dry clothing.
I've searched but haven't found my particular issue. The dryer gets warm but not hot enough to dry the clothing or advance the automatic timer. When viewing the igniter I can see it glow and it successfully ignites the gas and shoots a flame for about 10 seconds. It then goes out for about a minute and repeats. In the past when I had a similar problem I replaced the 2 gas coils near the igniter assembly. I tried this again with no success. Any ideas what may be at fault? Thermostat? Thanks.
좋은 질문 입니까?
댓글 1개
I'm having this same problem. LG gas dryer, was working fine, moved to a new house, reconnected gas line, vacuumed out the existing vent hose and cleaned the outlet from the dryer (neither showing much accumulation). Hooked it all up, and even at the hottest dryer setting, I'm just getting lukewarm air.
I'm guessing the thermal fuse will cut off all heat? If so, what else could cause partial heat? Inadequate gas flow? Other ideas?
Rich Shiba 의
