주요 콘텐츠로 건너뛰기
iPad 2세대, Wi-Fi, GSM 그리고 CDMA 모델이 있습니다. iPad 3 출시 전에 일부 모델을 새롭게 하였습니다. 수리는 어렵고 열과 비집기가 필요합니다.
729 질문 전체 보기
Ipad 2 still won't charge after battery, dock charger, cable replaced
I am fixing an Ipad 2 for a customer. The problem is that the Ipad would no longer charge. The customer said they tried different cables. I triple checked their troubleshooting with 3 different cables and as the customer said that wasn't the problem. Since it is a 2nd generation I figured the battery was going so I replaced it. After that it still wouldn't charge. Next thing was the dock connector. Replaced that and it still won't charge. I did notice the customer is using a 3rd party charger. I know 3rd party chargers don't regulate power as the original Apple chargers which is why you get the "This accessory may not work reliably with this device" message. I know that 3rd party chargers can fry the motherboard. But even though it is a 3rd party charger I don't get that message when plugging in. So it should be fine? So if it is not the cable, not the battery, and not the dock connector what could it be?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
its probably the power ic chip
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
This is the same problem my daughter's iPad is having, though hers is a 3rd generation. Without being plugged in, the screen shows that battery being charged (??!!).
댓글 달기
귀하의 답변을 추가하세요
Ryan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 135
