Size of logic board in a1151 and a1229 identical?
Can you put the logic board of the a1151 into the a1229's body?
좋은 질문 입니까?
좋은 질문 입니까?
You would need to replace a lot of parts, as the connectors on the A1151 are different from those on the rest of the original 17" MBP models. Also, the keyboard and left I/O board, while identical in form factor, are actually incompatible.
해당 답변은 도움이 되었습니까?
Hi Ben
to follow up on the discussion, if I want to change the A1151 board on my MBP by a 1229 (or 1261) board, I will also need to change:
- the left/right fans (or connectors)
- the left/right thermal sensors
- the I/O board
- the keyboard
is there any other parts?
thank you
해당 답변은 도움이 되었습니까?
Then try this one. It says compatible on MacBook Pro 17" Models A1151 A1212 A1229 and A1261
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,340
