주요 콘텐츠로 건너뛰기
Samsung Galaxy S3는 안구-추적 기능, 늘어난 저장 용량 및 무선 충전 옵션을 갖춘 멀티-터치, 슬레이트-형식 스마트폰입니다.
459 질문 전체 보기
(Can't connect to camera) S3 i9301 with CM12
Some days ago I installed a Resurrection Remix Rom (I actually don't know which one, sorry. I just know that it's got Lollipop) and when i went to the camera it said: <<Can't connect to camera>>
I still had warranty, so I installed the stock rom (I checked the camera and it still didn't work) and I sent the phone to the company. IMPORTANT NOTE: In the warranty ticket it said <<SOFTWARE ERROR>>
The only camera I can use is the "selfies" one
When I received it, the error was fixed, so I tried to install another ROM, so I installed CM12. But... I got the error AGAIN and I haven't got warranty anymore
That's what I tried
-Install Reset Camera and Camera (CMFix) (Camera CMFix didn't open and I had Restart Camera Installed :v)
-Checking if an app is having troubles with the camera
-Rebooting in safe mode
-Holding down the volume/power/back
-Clearing Data and Cache of the camera
-Removing my SD card
-Renaming the DCIM folder
- youtube. com/ watch?v=Fa9qggQJ990 (I can't even access to that menu ._.)
-Find “Use NuPlayer” and uncheck it & restart
-Using other camera apps
-Disabling the Google Camera and using the default one
-EDIT: I installed the Stock Rom with odin and did a factory reset. I even did a "system reset" with odin. AND IT STILL DIDN'T WORK OMFG. Then I tried to update the camera firmware (youtube. com/ watch?v=Fa9qggQJ990) because I've got KK now, but the "Phone/CAM FW Ver Check" is disabled. I googled my camera Cam FW Ver and it's not old
Thank you, I'ts a really annoying error. My S3 is giving me too many troubles, I'm starting to hate it... But I can't buy a new one
OHMYGOD I CAN'T FIND A WAY TO FIX THAT ERROR HELP PLEASE
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
I had experienced the same problem,
I could solve it thanks to the fix given here for i9301q
https://forum.xda-developers.com/galaxy-...
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Also CM is discontinued. Use LineageOS.
댓글 달기
귀하의 답변을 추가하세요
Mario Ortiz 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 991
