주요 콘텐츠로 건너뛰기
Improved second generation Google-branded tablet with a 7" screen.
98 질문 전체 보기
Nexus 7 Device Charging Help
Device stopped charging. Replaced charging port and still wont charge. Lock screen does not indicate charging. Tried multiple chargers. Replaced battery and conditions remain the same.
Any advice?
Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
Check you cable try a different usb charger some times the block from asus goes bad and would need replacing
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I have tried multiple chargers. Ones that work in other devices and it has no effect.
Thanks
댓글 달기
the asus brick not the cable
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
I no longer have an asus charger brick or cable. I have two other Nexus 7s and they charge with these other chargers. Can I even buy an Asus charger at this point? Should I try that?
yes ebay carries them cheap
asus sells the bricks with them because of certain amperage needed to charge the tablet not every tablet take the same amperage
댓글 달기
귀하의 답변을 추가하세요
pmcint01 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 116
