주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2189 질문 전체 보기
The bottom part of touchscreen is not working.
I replaced the display on phone and the bottom part of the display is not working I can't get the that menu where you can turn on/off wifi, flashlight etc. Last screen worked jsut fine, it was cracked but the touch worked everywhere.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
It's your parts. It's possible they were damaged during the install, or even during transit. However it's more likely that you bought cheap(ish) parts, and they aren't working upon assembly. Try this
iPhone 4S Screen
iPhone 4S Screen 이미지
상품
iPhone 4S Screen
$34.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
You said the old one was cracked and the screen function worked fine, try putting the old one back on and check if half bottom is working or not. If it works then you know you have a defective screen if it does the same then you have to troubleshoot down to board and check connectors for bent or missing pins on board where the LCD ribbon cable connects.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
mariozunic 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 267
