주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Home button and microphone don't work but touch ID does?
Couple of days ago I opened up my phone to clean the camera because there was a lot of dust in front of the lens and it was making pictures look weird. I was really careful when opening but for some reason my home button and mic don't work anymore. However, touch ID still works fine. But having no mic on a phone kinda defeats the purpose of the whole thing... I read that people are advising to look for the black knob and I did. Its still there and sticking out like it should. I also tried removing the cable and putting it back multiple times with restarts of my phone but nothing happens. I don't really mind the home button because I can just use assistive touch but it's still a little more convenient to just use the button itself. Last thing I read was something about FL5 but I can't find anything about it so I gave up on that one. If you want me to post pictures just ask i'd really like this fixed.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Not sure if this will work, but it's a lot different than just restarting the phone. Try disconnecting the home button cable, the lightning dock cable, and the battery. Then go in reverse
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
Do you mean unplugging them while the phone is still turned on? And is the lightning dock cable the one next to the battery connector? (I would like it if I don't have to take the whole thing apart :D)
Believe you me, that's not taking the whole thing apart. Yes, just disconnect those, see if that solves the problem. Otherwise you damaged something, while "fixing" your camera lens. Which probably means you need a new lightning dock
Thanks, I'll try that!
I haven't been able to try what you suggested since I didn't have a lot of time this week. But I did notice my headphone jack is also not working properly. When plugged in around half way the sound is normal but once pushed in completely I get a crackling noise. Would this mean I have a problem with my dock or could this also be a broken connection?
Sounds like a broken lightning dock
댓글 달기
귀하의 답변을 추가하세요
MisterMisterious 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 103
