주요 콘텐츠로 건너뛰기
Samsung의 5-세대 Android-기반 Galaxy 스마트폰은 2014년 4월 11일에 출시되었습니다. 이 휴대폰은 지문 스캐너, 최신 카메라, 대형 화면 및 방수 기능이 개선되었습니다. 네 가지 색상으로 제공됩니다; 검정, 파랑, 흰색 및 구리.
577 질문 전체 보기
Why doesn't the touchscreen work
The charging port of my Galaxy was just replaced, the phone turns on, the phone reads my finger print and goes to the right screen, everything looks normal as I can see and hear it taking texts, updates and calls but the touch screen doesn't work when I try to actually use the phone. What could be the issue, is there anyway to fix it?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
선택된 답변
Hi,
Try booting your phone into 'safe mode'. This will load only the OS and not any 3rd party apps that may start up on boot.
If it works normally in safe mode there may be an app which is preventing you from using the touchscreen. You will then have to find out which app is giving you the problem.
This will be a long process, depending on how many apps you have. In safe mode, back up your phone using the backup feature. Then uninstall either one app at a time or a group of apps (ones that you have installed not ones that were already there) then try starting the phone normally to see if it works. If it still doesn't work you will have to go back into safe mode to uninstall some more until you find the one. Make a list of the ones you uninstalled. When you find the one that was causing the problem, you can restore your phone using the backup that you made. This will however reinstall the app causing the problem. Go into safe mode to uninstall it then hopefully you should be fixed and up to date. (You may wish to do the above with the charger connected. Saves any bother of the battery dying when you are doing things).
If it fails in safe mode, you could try a hard reset to see if this restores full function to your phone.
Here is a link which describes various options on how to start in safe mode:
http://www.redmondpie.com/how-to-boot-in...
Here is how to hard reset your phone.
Be aware that a hard reset will erase all your downloaded apps and user data and will restore your phone to a default factory condition. It will be like when you first bought it
Before you perform a hard reset ensure that the battery is fully charged. Do not perform a hard reset with the charger connected.
1. Turn the Galaxy S5 off.
2. Press and hold the Volume up button, the Home button, and the Power button together until you see the Android on screen, then release the buttons
3. Use Volume down to highlight the wipe data/factory reset option and press the Power button to select it.
4. Use Volume down again to highlight ''Yes – delete all user data and press Power to select it.
5. Wait until you see the reboot system now option and then use the Power button to select it.
When the S5 restarts it should be completely wiped and ready to set up again.
Be patient it takes a few minutes
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
I did a factory reset on mine after replacing the charging port because the screen turned on and everything but didn't work by touching it. My keys and buttons work though. Is there anything else I can try?
Hi, You might have to check the LCD cable/cable connection as it may have been damaged when you opened the phone to repairthe charging port. Or the digitizer may have been damaged when you opened the phone to get to the port.
댓글 달기
귀하의 답변을 추가하세요
Jenne 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 6,470
