주요 콘텐츠로 건너뛰기
Repair and disassembly guides for GE Microwave ovens.
349 질문 전체 보기
microwave not coming on
is there a fuse in the microwave that if blown stops it from coming on
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 2개
This is a microwave/convectional over combo....I am having this microwave problem too, and also having problem with convectional oven. Theirs a "F7" & "40* on display. Does not turn on anymore. Any suggestions????
@mayer, Hi I'm new to using this website, so I don't know how to ask you a question without being inside a thread. I hope you can help me. I have a GE Microwave JVM3160RF3SS above cooktop unit. I had the apparantly bad habit of opening the door to stop the unit rather than hitting end on the control panel. One day, as I opened the door during use, there was this little spark as I opened the door and the unit has been deacd ever since. I followed the instructions to get to the fuse, and it looks both broken inside and burned out. How do I remove the fuse safely? The unit has been unplugged for months, but I know there is danger of electrocution even in light of the duration without power. Can you or someone else please tell me how to safely replace the fuse? I also understand that the fuse may have blown because of a bad door switch due to the way I was opening the door during use. I will check that second if replacing the fuse doesn't solve the problem. I would appreciate fude removal tips. Thank you.
댓글 달기
답변 3개
선택된 답변
Yes there is a fuse. Please give us your model number. But remember, if it is the fuse, it blew to protect the machine.
해당 답변은 도움이 되었습니까?
점수 4
댓글 2개:
ge household microwave oven
@mayer, Hi I'm new to using this website, so I don't know how to ask you a question without being inside a thread. I hope you can help me. I have a GE Microwave JVM3160RF3SS above cooktop unit. I had the apparantly bad habit of opening the door to stop the unit rather than hitting end on the control panel. One day, as I opened the door during use, there was this little spark as I opened the door and the unit has been dead ever since. I followed the instructions to get to the fuse, and it looks both broken inside and burned out. How do I remove the fuse safely? The unit has been unplugged for months, but I know there is danger of electrocution even in light of the duration without power. Can you or someone else please tell me how to safely replace the fuse? I also understand that the fuse may have blown because of a bad door switch due to the way I was opening the door during use. I will check that second if replacing the fuse doesn't solve the problem. I would appreciate fuse removal tips. Thank you.
댓글 달기
GE Stainless Steel Microwave GE PEB7226SFSS 2.2 Cu. stopped suddenly during cooking.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
It is possible to fixa microwave oven that is not heating, but you have to be careful and take precautions. Read the description of this video and watch this
https://youtu.be/WAf18e8sW4E
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
bandkdixon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,658
