microwave not coming on
is there a fuse in the microwave that if blown stops it from coming on
좋은 질문 입니까?
좋은 질문 입니까?
Yes there is a fuse. Please give us your model number. But remember, if it is the fuse, it blew to protect the machine.
해당 답변은 도움이 되었습니까?
ge household microwave oven
@mayer, Hi I'm new to using this website, so I don't know how to ask you a question without being inside a thread. I hope you can help me. I have a GE Microwave JVM3160RF3SS above cooktop unit. I had the apparantly bad habit of opening the door to stop the unit rather than hitting end on the control panel. One day, as I opened the door during use, there was this little spark as I opened the door and the unit has been dead ever since. I followed the instructions to get to the fuse, and it looks both broken inside and burned out. How do I remove the fuse safely? The unit has been unplugged for months, but I know there is danger of electrocution even in light of the duration without power. Can you or someone else please tell me how to safely replace the fuse? I also understand that the fuse may have blown because of a bad door switch due to the way I was opening the door during use. I will check that second if replacing the fuse doesn't solve the problem. I would appreciate fuse removal tips. Thank you.
GE Stainless Steel Microwave GE PEB7226SFSS 2.2 Cu. stopped suddenly during cooking.
해당 답변은 도움이 되었습니까?
It is possible to fixa microwave oven that is not heating, but you have to be careful and take precautions. Read the description of this video and watch this
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,658
댓글 2개
This is a microwave/convectional over combo....I am having this microwave problem too, and also having problem with convectional oven. Theirs a "F7" & "40* on display. Does not turn on anymore. Any suggestions????
Ricardo 의
@mayer, Hi I'm new to using this website, so I don't know how to ask you a question without being inside a thread. I hope you can help me. I have a GE Microwave JVM3160RF3SS above cooktop unit. I had the apparantly bad habit of opening the door to stop the unit rather than hitting end on the control panel. One day, as I opened the door during use, there was this little spark as I opened the door and the unit has been deacd ever since. I followed the instructions to get to the fuse, and it looks both broken inside and burned out. How do I remove the fuse safely? The unit has been unplugged for months, but I know there is danger of electrocution even in light of the duration without power. Can you or someone else please tell me how to safely replace the fuse? I also understand that the fuse may have blown because of a bad door switch due to the way I was opening the door during use. I will check that second if replacing the fuse doesn't solve the problem. I would appreciate fude removal tips. Thank you.
ESO12 의
