주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
질문 마감됨
Entire screen separated from lcd during battery replacement on iPhone
While beginning the steps for battery replacement on iPhone 5, the screen lifted without the LCD . I was caught off guard to say the least. I was using the suction cup method to lift the screen assembly. I applied slow and constant pressure, when the screen showed signs of lifting, I used the plastic spunger tool, beginning in the lower left corner, to work the screen assembly free. Once it lifted, I confirmed that I was only getting the glass by comparing what was lifting for me to the pictures and video in the iphone 5 battery replacement guide by Andrew Optimus Goldberg. I have been searching both the iFixit site as well as trying different Google searches. I am unable to find any information as to how to proceed or even if I should. I have found nothing that explains how to get the LCD assembly out if it is not attached to the glass. Everything I read tells me that separating the glass from the LCD is an extremely difficult procedure. Since I have been unable to find the necessary information, I put the phone back together and will wait until I'm able to get a response. The information I have found so far would seem to imply that heat is what is the general cause of the glass and the LCD to unbond. The phone is carried in a breast pocket of a shirt for the most part. Occasionally in the hammer pocket on shorts or work pants. Heat during charging has not been a problem. With the phone back together, there don't seem to be any problems with lag or the screen appearance having issues. Any help would be greatly appreciated!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Pull the rest of the frame off, reattach a new frame with a glue when putting everything back on.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
The frame is not the problem. The screen, the glass part, has separated from the LCD. I don't know what glue to use to put them back together. Obviously it will have to be heat resistant. Other than that I don't know what to use. Only around the edge, or across the face. How do I lift the LCD screen without damage? Neither the screen or the LCD need to be replaced, just the battery. I do appreciate your prompt response however the phone is no longer accessible to me. Will be again in April and I am certain will still have the same problem.
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 107
