A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
886 질문 전체 보기
Power Supply Replacement (none work)
So I bought a power supply replacement from iFixit.
Followed the steps to replace it and I'm still getting the same problem. If I send it back will they send me another one to see if it works? Thanks
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
I'm going to go out on a limb here and guess that your PS4 is turning on then right back off. If this is the case then it's not the power supply that's causing the problem. This problem is usually caused by a faulty APU or the solder joints between the APU and motherboard.
Let me know if there is some other problem that you are trying to fix.
I hope this helps.
해당 답변은 도움이 되었습니까?
점수 3
댓글:
So is there a way for me to fix this?
의 답변
Unfortunately not a good way right now. Your best bet is to have it repaired by a repair shop.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
pwnstar121 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 97
