주요 콘텐츠로 건너뛰기
LG에서 제작한 터치스크린 스마트폰 모델 번호 VS980는 2013년 9월에 출시되었습니다.
185 질문 전체 보기
once I lock it I cant unlock it
Hello,
I have Lg G2 D802 version. I turn it on but once i lock it i cant unlock it anymore. When i press power button backlights turns on for 2-3 sec and turns off. Only way to use phone is to restart it.
I have tryed to put new OS, new LCD assembly, 2 new battery.
Any solution?
Sheers
UPDATE:
replace USB PORT AUDIO JACK HEADPHONE PLUG FLEX PCB
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hi Nikola,
Has your update fixed the problem?
If not, it is likely the proximity sensor. Have you opened the phone up before it started, replaced screen?
Do the following tests.
Simple:
- take the phone next to a very strong light (for just a couple of seconds, you don't want to melt it) and press the power button. Does the phone wake up?
Medium Complexity (be very careful not to fry the motherboard or screen by static - do at your own risk)
- turn off the phone
- take off the back cover and the top motherboard cover.
- carefully remove the proximity sensor from its nest, so that the sensors are facing the light
- very carefully turn on the phone back on
- once the phone is on, put it to sleep and try to wake it up again either with tapping screen or power button.
- turn off the phone (completely power it down)
- reassemble
If either of these work, your proximity sensor just needs to be wiggled a little in its nest so that it is picking up light. Make sure it has it's rubber 'glove' still on.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Nikola Santek 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 74
