주요 콘텐츠로 건너뛰기
A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1697 질문 전체 보기
Disc drive accepts and audibly spins discs but games aren't installing
After taking apart my PS4 to change the thermal paste and clean the fan, my disc drive accepts the discs like normal and you can hear it spinning them, but the game tile never shows up on the PS4 home screen. It seems like the disc drive isn't actually reading the discs.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Could try this
https://support.us.playstation.com/artic...
Happened once to me, but it was the game server, that seemed to be the issue...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
It's quite likely that you may have torn or damaged the large ribbon cable going from the motherboard to the disc drive (I'm assuming that the disc drive worked before you took it apart). If this ribbon cable is crooked at all or not quite in the connector all the way it can cause this type of problem. I've seen many times where the little ears on each side of them get torn off and then won't lock in place like they should.
I hope this helps.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
yes, the little ears on my ribbon cable are torn off. Where can I buy a new ribbon cable for that?
I'm sure you can find them on Ebay. the real problem though is that the ears are most likely stuck inside the connectors. They are very difficult to get out and sometimes it requires replacing the connectors.
You might try a new cable and see if you can get them in straight.
댓글 달기
귀하의 답변을 추가하세요
illuminati Confirmed 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 93
