주요 콘텐츠로 건너뛰기
The LN46A530 has a 46" display, combined with SRS TruSurround XT. The PC input allows this display to double as a 46" computer monitor
70 질문 전체 보기
HDMI Problems and connecting
'''bold textMy HDMI cable attach from my notebook to the HDMI port on my Television is not working as it should be. When attach, all I am getting is the icons on the taskbar but none on the desktop and a different screensaver, I have tried unplug the television for 10 min, plug it back on, reconnect the hdmi cable, I usually use HDMI2, that did'nt work also the other HDMI port.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개:
Hi,
Can you try a different device on the HDMI inputs of your TV, e.g a dvd player or anything with a HDMI output? This is to isolate the problem to either the TV or your notebook. Also if you can try a different HDMI cable, again to eliminate possibilities.
댓글 달기
답변 1개
Did you use separate screen option? Or duplicate?
Is this the first time you used an Hdmi?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Roderick Maloney 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 170
