주요 콘텐츠로 건너뛰기
The Canon Powershot A1000 IS features a lens with 4X optical zoom and a focal length of 6.2mm to 24.8mm and maximum f-stops of f/2.7 and f/5.6.
6 질문 전체 보기
질문 마감됨
Can't close battery cover, because of small plastic broke
So this little plastic hole just broke, don't know how to repair that. It's annoying, because for this time I'm using ducktape, but it's not practical, when you need to pull of sd card.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Are you referring to the clasp that holds the battery cover down?
댓글 달기
답변 2개
Hi. Probaly u will need to replace entire housing of camera.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Do you have the little plastic hole with you? If you do then super glue it back on.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 170
