주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
power/sleep button doesn't work
My iphone 3gs got wet a few months back. I took it apart and dried it out and got everything working except the power button on top and the camera.
So I ordered a new camera module and a volume/headphone/power button flex cable assembly and replaced the parts.
Now the camera works fine, but the power button still doesn't work. All the other parts of the flex assembly work, like the headphone jack, the mute/vibrate button, and the volume control.
The power button is still non functional though. It clicks very well, but nothing happens.
What could be the problem here?
Just in case it helps, I've found that one of the little flex cables that connects the display to the logic board (I think it is labeled '3') doesn't seem to really go in the way it should and appears loose. This is probably unrelated as the teardown for the 3gs seems to indicate that the '3' cable is for the ear speaker, but I thought I'd mention it..
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
no 3 doesn't fit all the way in to the connection, as long as it works don't panic!
댓글 달기
답변 3개
선택된 해법
try loosening or tightening the screws on the power button flex
이 답변이 도움이 되었나요?
점수 2
댓글 달기
I am in the same boat you are. Everything works fine on my 3GS, except the sleep/power button, and it clicks fine, just no response. I really only care about taking screen shots and without the button functioning, it cannot be done.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
same boat. new bottom half, with cables and all, so it appears that the sleep/power button failure is on the mobo. I wish I had a diagram of the connection points where the flex ribbon connects, as I think this is where the problem is - on the main board. Anyone?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Cliff 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 3,409
