주요 콘텐츠로 건너뛰기
지난 20년 간의 Mac 노트북 수리 설명서—iBook, PowerBook, MacBook, MacBook Pro, MacBook Air.
30490 질문 전체 보기
PCIe SSDs interchangeable between MacBook Air E.2015 and Pro M.2014?
Are the SSDs between these two models interchangeable? Even if it would run slower in the older model. Apparently, between 2015 Air and Pro models, they are.
As I have a scratched up MBA with 512GB and a near-mint MBP, so I'd like to switch disks.
The MBA Early 2015 has:
"APPLE SSD SM0512G"
Vendor: Apple
Product: SSD Controller
Physical Interconnect: PCI
Link Width: x4
Link Speed: 5.0 GT/s
Description: AHCI Version 1.30 Supported
The MBP Retina Mid 2014 has:
"APPLE SSD SM0256F"
Vendor: Apple
Link Width: x2
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
i also have a 2015 MBA and 2014 MBPR. i suppose i could crack them open and see, but has anybody tried this or can you confirm/deny the compatibility?
댓글 달기
답변 1개
선택된 답변
Sadly No, If you note the Link Width you have two different units x2 and x4.
Think of it this way two gallons of water won't fit into a one gallons bottle.
해당 답변은 도움이 되었습니까?
점수 2
댓글 6개:
Yes I had noticed that, but in my scouring of the web, I found an article in which the placement of an SSD from a Mac Pro into an MBA (I believe, it might've been a pro) furnished a 150% speed increase, citing the 2x and 4x lane difference.
I had assumed it was comparable to the days when you could interchange AGP 2x, 4x or PCI xN devices, and the bus would sort it out. It's not my intent to argue your answer, but I'm curious if anybody has actually given it a whirl.
Actually they are interchangeable. I have a MacBook Pro 2013 late, and switched my broken ssd with 2015 version, it now not only works but speed increased to almost double amount!
Please post a link that states these SSD's are interchangeable. That would be a surprise if the older logic board had support for a 4 lane SSD.
Timur, was that between MBA and MBP? or MBP and MBP? The internet says whatever it wants to, right or wrong. I'm excited to read anecdotal evidence of this working!
https://flic.kr/p/HsqKiB
Here's the screen of my MB with new SSD.
Ronnoc, i'm not sure, new one is from eBay seller didn't mentioned origin of that ssd.
댓글 1개 더보기
댓글 달기
귀하의 답변을 추가하세요
sergeymkl 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 1,021
