Can I fix my bluedio headphones sliders?
I have broken my headphones sliders, I hope you have some great ideas how can I fix them :) (image link below)
좋은 질문 입니까?
좋은 질문 입니까?
Hi,
If you are the only one wearing them and 'looks' aren't a problem and you don't have to adjust them too often, you could try the following:
1. Make sure that they are adjusted to how you like to wear them.
2. Place a piece of reinforcing material* on both the inside and the outside of the band, overlapping the break, if possible by about 1'' (25mm) either side of the break, (2" (50mm) long piece of material on both sides in other words).
3. Wrap tightly with duct tape or similar strong adhesive tape, overlapping onto the band at each end.
해당 답변은 도움이 되었습니까?
try 5 second fix or laser fix but i fixed mines
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 6,590
댓글 5개
Is it possible to find replacement parts, or something, cause I have to adjust them ( ?
Deyn God 의
try 5 second fix or the laser or lazer fix or bond im fixing mines right now u may have to take it apart to bond it right and correctly
wild1hunnets 의
I broke mine and the slider slid into the headphone where I can't reach it. What should I do
Chris walker 의
Happened to me too on BOTH my Bluedio headphones !!
thorirbra 의
A 3D print might solve the problem.
But is need someone with patience to replicate
the slider on the right size and post the 3D scan for free.
3D print centers started to be available and more affordable.
Cher Wally 의
