Fix cracked wii remote front
I cracked the wii remote front infrared panel while bowling, now it doesn't point. Can this be fixed? All other functions are still working.
좋은 질문 입니까?
좋은 질문 입니까?
The tri-wing needed to open your remote is also available in iFixit's driver kits.
[연계 제품이 누락 또는 비활성화 됨: IF145-022]
[연계 제품이 누락 또는 비활성화 됨: IF145-028]
해당 답변은 도움이 되었습니까?
You can try just unscrewing the case and removing the front cover and see if that helps. The front cover is just a filter that only passes infrared light (and keeps dust out). But if you damaged the sensor inside, then you'll need a new Wii remote. To unscrew the case, I believe you need a tri-wing screwdriver, which you can get at Ebay. If the sensor is damaged, you can sell the remote to a hacker who only needs it for the accelerometer.
해당 답변은 도움이 되었습니까?
This is what I did to my remote and it works perfect http://howtofixstuff.blogspot.ca/2013/08...
해당 답변은 도움이 되었습니까?
The front of the wii remote had a cracked screen because my older sister or brother and me were playing just dance 1 2 3 or 4 she or he kept on hiting it out of my hand. XD is that your problem.
해당 답변은 도움이 되었습니까?
Follow a guide for your wii remote, but before that, make sure you buy a replacement case/screen.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 8
30일 전: 17
전체 시간: 6,230
