Saved Imei in iPhone
Where it is saved in the iPHone IMEI?
좋은 질문 입니까?
Settings>general>about
해당 답변은 도움이 되었습니까?
Sorry. I was thinking in hardware IMEI
Only on the outside of the phone. I don't believe it's printed anywhere on the logic board
Every phone has a unique IMEI: And I ask where is the IMEI is stored in which a chip. If I wanted to change the IMEI what CHIP must be replaced.
I can't advise you to do this. It would contribute to stealing
Dial *#06#
Changing the IMEI is possible but also illegal.
You can't, period.
Apple is a group of control freaks, they paired and encrypted almost every chip that has logic functions. So replacing just some of the chips will destroy the device.
For example in order to replace IMEI, the baseband and baseband flash ROM chip must be replaced together as a set, or the device dies. Also the device S/N must be rewritten to pair with the IMEI, or the phone will be denied activation. Rewriting S/N is not yet possible for iPhone 6s, so just forget about replacing chips.
If you replace the logic board, you'll run into another problem. The Touch ID sensor is paired with the CPU, Touch ID dies immediately when you replace just the board, and if you attempt to reinstall iOS, jackpot, the phone dies.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 664
댓글 1개
could you possibly rephrase the question?
Wesley Burson 의
