주요 콘텐츠로 건너뛰기
Released September 2015, the JBL Xtreme is a portable, Bluetooth speaker that is also splash proof.
102 질문 전체 보기
Is it possible to check the speaker internally?
I would love to see inside it. Many people have purchased this model. thank you
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 2개
가장 유용한 답변
@atomic take a look at this video
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
See inside as in open it up? I had to open mine up because I dropped it and I wouldn't recommended it. The item is non-repairable as stated from manufacturer, and if you open it up like I did, you won't be able to close the casing as tightly as in original condition (I presume the waterproof tolerance has been affected because of this). There is some glue underneath the casing so I suspect this helped hold it in place.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
arash 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 1,400
