주요 콘텐츠로 건너뛰기
Fourth generation Honda Civic
33 질문 전체 보기
Water pouring out! Is it the radiator only or possible other problems?
Hit a curb in my 1988 honda civic. I am not a car guy at all, but I can replace a radiator. Before I do this I want to make sure the water pump or anything else involving the coolant system was not damaged. This I don't know. I'm also looking for a diagram/photo of the bottom of the car.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
First of all you need to pressure test the cooling system to see where exactly is leakege coming from. This process tests the integrity of the cooling system, by hooking up a pump into the radiator with the respective adaptor for your vehicle then pump up to 15 or 16 psi, Do Not exceed this pressure as you can damage even more the cooling system, then pay attention to the needle and see if presure drops significantly and if it does you cannot miss where the leak is coming from. A healthy cooling system should maintain 15 psi. Regarding the water pump, when they go bad. two main things happen: you hear a noise coming from the side your water pump is located , which could be the bearings on pump are going out and have failed, and also there is a weep hole where coolant comes out which means water pump is going bad. To test water pump, turn car on, squeeze upper radiator hose, hold for a few seconds, then release and if you feel a surge inside hose, it means the water pump is pumping coolant throughout system. Also, you can remove radiator cap, while car idling and you can see if the coolant is circulating. But only do this when you first turn car on not after it has been running as you can burn yourself. Hope this helps.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thank you for such a detailed response. It is fixed!
댓글 달기
Put it up on a rack and look to see where the water is coming out and where, if any damage occurred.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
jalago52 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,635
