주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Replaced lightning connector, now phone won't charge at all
Was having issues with phone charging. Would have to wiggle the cable around until I found a spot that would charge and if I move the cable it would disconnect. So I replaced the connector, the audio jack works and speaker works though nothing happens now when I try to charge. Also replaced the battery at the same time.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Hard to say. Likely one of these parts is not working. What you're going to have to do, is exchange them, and find which one is the problem. Lucky thing is, guessing because you changed them both out, you wanted them both to be changed. If you had a voltmeter, you could determine if the battery was the issue
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
I have put the old battery back in and still same issue.
Ok, so I would think that the new lightning dock is the issue then. You can likely exchange it and get a new one. Sometimes parts just come out of the factory broken
댓글 달기
Also dry fit the new lightening connector before you install it, connect the connector to the motherboard and lay the lightening connector to the right of the phone and plug in using original apple charger. This way you can make sure the phone is charging and working before you go through the work of the install only for it not to work.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Probably a stupid question considering the forum, but 19/20 of our customers looking to replace the charging port only have dusty/filthy ports. Have you tried cleaning your original charging port with a tweezer?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jack 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 200
