주요 콘텐츠로 건너뛰기
Repair and troubleshooting information for the Suzuki FA50 Moped.
75 질문 전체 보기
loss of power upon acceleration
So i Hae some chinese moped thats 50cc used to run fine and could do 40+mph ut now something has happend i live in NY so i dont know if it is the cold. But when i turn on the moped it idles fine like a dream and will rev fine, but as soon as i sit on it and try to push the throttle with weight on it it bogs down after a couple of seconds any suggestions? it almost feels as if there is zero tourqe
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Hi, Since you say that it dies with weight on, a fuel line is not being 'pinched' or that the wheel is not being jammed or brakes being applied. Sounds silly but can you transfer the 'weight' to see if it has any effect? Stand on the pedals perhaps instead of sitting down.
@supercarsny what make is your moped since you referred to it as a "chinese moped"?
댓글 달기
답변 3개
가장 유용한 답변
@supercarsny sounds like some carb adjusting is needed to me. You want to start with the air/fuel mixture screw first. Also check your float height and make sure that the level is right and that the needle valve is not stuck.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
the oil pump well kind of pump is over saturating the plug. best way to fix this is to bypass the oil line (block it) and premix oil and fuel and run that way. good luck
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Check to make sure your choke cable is positioned correctly.these little engines usually take a while to warm up. Before u can open choke all the way
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
sloan senell 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 5,721
