How do I replace the battery in the LeapFrog Platinum?
How do I change the battery? The company says it cannot be replaced but I want to know for sure.
좋은 질문 입니까?
좋은 질문 입니까?
I'm assuming you want to replace the battery because you are having issues with battery life or because your LeapPad won't turn on. May I suggest checking out the troubleshooting page to rule out a simpler solution before you tear your device apart? The battery is kind of a pain to replace so I want to help you avoid that if I can!
If you determine the battery does indeed need to be replaced, it is possible to do so. My team and I will be writing a battery replacement guide very soon, so keep a look out for that!
해당 답변은 도움이 되었습니까?
The battery replacement guide is updated, you can check it out now.
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,743
