주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 더 큰 Apple MacBook Air 노트북 입니다.
Trackpad and Keyboard not working after login
Hi, yesterday I was just using my laptop like usual and all of the sudden my keyboard and trackpad stopped working. My cursor moved to the top left corner of the screen and was stuck there. Then my laptop opened up the bluetooth subject in systems preferences and started to search for an external keyboard. None of my keys were working except my power on/off. I tried restarting it a bunch of times, nothing worked. I left it over night and it started working again fine this morning, then two hours later did the same thing. I waited a few hours, it started to work again and here we are.
Does anyone know how to get this to stop permanently myself?! I have three midterms next week and absolutely need my laptop for them, I can't be sending it away to be repaired right now!!!
Also, the weird thing is, that my trackpad and keyboard work fine on the login screen, I am able to enter my password and everything but as soon as I login it freezes up and keeps searching bluetooth for an external keyboard.
Please help!!!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 3개
I have the same problem, could not find a solution yet.
Same problem. Keyboard and trackpad work only in login screen. After login they wont work. My bluetooth mouse works. Don't have an external keyboard to test but I'd suspect it would work. Tried safe mode and keyboard and trackpad wont work there. Tried new trackpad and cable but problem still same.
Same problem with me, just happened after I replace my battery. Now I use bluetooth keyboard all the time. Tried all the help I can get from the internet but still fail until now
댓글 달기
답변 1개
가장 유용한 답변
Do you have access to an external USB keyboard & mouse/trackpad? I would give that a try so you can diagnose things.
Most likely you either had spilled something into your keyboard (it might even be dry now) or the battery is pressing from below interfering with the keyboard and trackpad.
To check your battery you'll need to install this app: coconutBattery. Paste a screenshot of what it is showing you in your question so we can see what its telling you.
The last possibility here is the keyboard/trackpad firmware needs to be upgraded. Under the About This Mac' click on the System Report... button to open the hardware profiler. Here we want to look at the USB section and we need to open the hub that lists the built-in keyboard & trackpad. Take a screenshot and post it in your question for us to see.
Update (07/18/2021)
Time to replace the trackpad! MacBook Air 13" (Mid 2013-2017) Trackpad and here’s the guide MacBook Air 13" Retina Display 2019 Trackpad Replacement
The trackpad in this series is the USB hub logic which both the keyboard and trackpad connect to. Then, the two signals travel up a common cable to the logic board MacBook Air 13" (Mid 2013-2017) Trackpad Cable which is also a song possibility of failing if you got your system banged or wet.
Replace the cable that connects the trackpad to the logic board compatible with the Mid 2013 to 2017 13 inch A1466 model MacBook Air laptop. Part #923-0441, 593-1604. 이미지
제품
$14.99
Replace a scratched or malfunctioning trackpad compatible with a Mid 2013 to 2017 MacBook Air 13" A1466 model laptop. 이미지
제품
$35.99
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I cannot find built-in keyboard & trackpad hub under the USB section
댓글 달기
답변을 추가하세요
Shannon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 3,498
