주요 콘텐츠로 건너뛰기
일반적으로 통합 스크린을 포함하지 않은 이동하지 않는 컴퓨터입니다.
1487 질문 전체 보기
"My PC is slow!" Advice on tune up software
Hi Guys,
I am the one and only IT Support Technician working at my company of around 150 users (each with their own PC / Laptop). The problem is, I really don't have time to fix the old "my PC is really slow, i can't possibly put up with it any more!" type of requests.
Currently when a person consistently complains then i am forced to format and rebuild Windows XP on their machines.
Alternatively (which is what i am getting at here), i would like to build up a "software kit" that i can install and run on the users computer without the need for formatting.
Currently i have;
SuperAntiSpyware to get rid of anything my enterprise version of Sophos Anti-Virus misses.
The Seagate and Western Digital disk scan tools (for fixing bad sectors and the likes)
A Copy of disk keeper for defragging.
does anyone else know of any tools that i could use for this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Do you have 10% free hard drive space?
thanks guys, i'll try malwarebytes, never heard of that one before. Yeah i know all about RAM and Hard Drive space :) i was looking for some software ideas.
Thanks again,
James.
PrivacyProTech is best tool for your Windows computer and devices for all security from malware, spyware and ransomware attacks. Just install our software and keep away from all these threats.
https://privacyprotech.com/
의견 추가하세요
답변 9개
선택된 해법
I hope I won't be fried on here for saying this, but CCleaner is a worthy tool for cleaning up the Windows registry of some junk that older programs leave in there. I've done MANY a clean and it never messed up my system (however let it backup the registry first!!). It also allows you to clean up the cache of different programs, which will also speed things up.
There will probably always be the occasional system that will have to be reformatted because it's really suffering from bit rot. But to make that installation go faster, slip-stream a Windows XP CD with the latest updates and store that installation on a USB key to make the installation a breeze.
Hope this helps.
T.J. Barber
해당 답변은 도움이 되었습니까?
점수 7
의견 추가하세요
www.malwarebytes.com for any and all things spyware. Free. I Install it on every house call computer I have.
mayer said it, make sure the hard drive has AT LEAST 10% free space, the more the better.
schedule disk cleanup and disk defragmenter to run frequently at off hours.
RAM. Can't have enough of it. Too cost effective to not consider. At least 2 Gb. I always used to see how many windows of office docs, system tray apps and web browser windows a person has open. The user can usually be the culprit to a lot of "its sooooo slow" problems.
Restart the computer in the morning before starting to use it.
Did I say RAM?
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
Some time ago, when I was working at a place as a tech, they used a enterprise licensed program called "deepfreeze"
It encrypts the OS and does a bunch of other stuff, we could make it so any client for your network will boot up the same time everytime, no matter what kind of crazy stuff is done to it. Alot of people did some not so smart things.
Not a cheap solution I imagine, I don't really know but for a smaller/medium company might not be all that bad (no idea on the cost), might be worth it if this kind of thing is a big enough problem.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
I use these tools:
1) Run Malwarebytes (fast) and maybe Spybot search and destroy to clean spyware.
2) Update Windows and antivirus.
3) Run CCleaner + CCleaner enchancer to clean old files from many programs.
4) Run registry defragger like Regseeker of any registry defrag software.
5) Run Auslogic disk defrag to defrag the disk.
Also check memory, free space, unused software, RAM, Extended Memory and I twaek a bit the OS (put Windows RAM use in best performance with just 2 options ..user doesn´t detect anything).
With these tips he/she will notice a GREAT improvement. Plus tell them to use Chrome, sometimes Slow computer is just a slow browser.
Smyth
www.smythsys.es
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
What u can actually do if u have been using ur pc for long is this procedure.
Fisrt if u are gona use ccleaner really have a backup of ur registry becouse it will mess up lots of times,, even more when u have a fragmentet hdd
so if u want to really do a Core tune up start from the core, your OS
Basically decide on what aplication u have installed u will use and what u will not.
What u will not uninstall it using a freeware uninstaller,in ur case Revo uninstaller will do becouse it has the option to delete registry keys and folder & files left by the program.Leave just alpications u use.
The second one optional at this point defrag and clean up
tool u will find in any windows and if u think u have a worse state than that skip this and get in ur pc a window cd,ur windows version cd to be precise
And make a repair of the pc,this will delete ur system replace it with a new one and not delete user files.After u start up start ur antivirus software and nothing else this will make the RE-WRITE of the antivirus software in the registry update if u have not and make a scan any virus wont have an escape this way becouse ur registry is fresh free now and no virus has accessed it yes.
After virus free machine just start up in ur aplications from the folders in program files.they will be there .they will also re-write themselfes in the registry,make shortcuts on desktop if u need, and after this defrag if needed.MAke a cleanup with the windows tool that is needed for sure.
100% sure this will give u a much more faster fresher and beter OS nad PC
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
I like revo uninstaller for removing software, very good.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
I do find that tools such as ccleaner and revo uninstaller are great programs, but one I am most impressed with is System Mechanic Professional. Alas, this software is NOT free, but it is one of the best tools you can find. It will do pretty much any kind of maintenance you can think of. You can also set it so that it does the maintenance automatically, so you practically never have to bother it.
Iolo System Mechanic Professional
For businesses: http://iolo.com/smb/
For 150 users... yeah, that's kinda expensive, but instead of displaying a price, it displays a button where you can contact iolo, so maybe they have some sort of deal?
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
Cleaning and optimizing the PC from time to time has various benefits. It not only improves the functioning of the computer but also boosts the speed and enhances its longevity. Also, threats like virus attack can be avoided with the best cleaning software. There are many reliable pc cleaning software available that can discard all the potential threats. Use Systemcarepro.net
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
You should keep optimize your PC so that it could deliver your smooth and fast performance.
There are many tool which helps to improve your system performance, you can get these tools via searching through internet.
해당 답변은 도움이 되었습니까?
점수 -1
댓글:
Jyoti Roy, it is not a Mac, but a PC running Windows OS. If you need to SPAM you should at least read the question.
Jyoti Roy, you edited your answer but missed the "improve your Mac performance" IT IS A PC. you definitely will have to work on your skills
@oldturkey
Sorry to bug you again about this, but this question needs to be edited too: Is it Possible for us to transfer iPhone voice memos to computer?
@Nikhil, consider it done ;-)
@oldturkey
의견 추가하세요
귀하의 답변을 추가하십시오
James Stoy 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 2,745
