high vibration when apply break speed between 100 to 80 km ph
very high vibration when applying brake between speed 100 km to 80 kmph
좋은 질문 입니까?
좋은 질문 입니까?
The vibration is probably the brake rotors .Look for small spots on the rotors .you want to see a smooth shinny surface and any discoloration or rust will cause vibrations. That will cause the pads to wear faster . If the car sits for days at a time the pads tend to rust or if the pads are heated a lot when cooling they can cause distorion and warping this also can cause a vibration The hardness could be coming off the rotors and if it is it will only get worse . So you may need to get the rotors changed soon
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 148
