주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
iPhone 6 plus touch screen doesnt work
Alright, I have read almost every article in here and can't find a fix. A customer brought in an iPhone 6 plus (all original). The touchscreen wouldnt work for anything. I followed many steps, before even attempting a restore and it wouldnt work. So I did the restore and finally got it to extract the software (customer had a passcode on it), so even after a factory restore, the touchscreen still doesnt work. Any ideas?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
If you've tried replacing the screen etc.
Then it sounds like the touch IC is damaged, it's apparently quite common for the touch IC to go in the 6 Plus.
To replace this, you would require knowledge and equipment to do microsoldering. :-)
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Yep. I'd bet my money on touch IC disease.
댓글 달기
Hi there,
I may have some solution without replacing hardware, please read below or follow link on the topic:
iPhone screen flicker and touch is not working
Hi there,
I had an Iphone 6 plus (model LL/A) with the same problem as you are.
I don't know exactly the mistake was come from firmware or hardware. However, as my experience now, i think it is caused by firmware.
When this problem happen to me, the iphone was at IOS 9.3.3, i tried to shake, lock and open screen, restart, press on some edges of the iphone even bang it softly then the screen respond correctly some times but this problem happen more frequent and i could't used the screen although i tried all above actions.
Then, I called to the Customer care of Apple, they asked me to bring my iphone to the care center for checking and fix. Because my iphone was jailbroken, i had to restore its firmware. I restored to IOS 9.3.5 due to IOS 9.3.3 was signature closed.
After the restoration, my Iphone 6 Plus worked very well in 1 or 2 days before the problem came again. This time, I tried my luck with IOS 10 (14A5346a). And boom, my Iphone have been well since last Wednesday 7th Sept.
I would like to share this with you and all technicians of ifixit.com with the hope for a completely cure to our Iphone. Apple has been revoked us, we have to help ourselves.
Hope this can help many people in the world.
(Please don't charge for fixing this problem by my shares)
해당 답변은 도움이 되었습니까?
점수 -1
댓글 달기
귀하의 답변을 추가하세요
matt mocciola 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 395
