Keyboard wont connect to tablet
Keyboard will not work after I connect it to my tablet
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
의견 추가하세요
US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
3개의 답변
선택된 해법
The HDMI port must be enabled for the keyboard to work. Go to display and check HDMI.
해당 답변은 도움이 되었습니까?
점수 6
댓글:
Thanks, that did the trick!
의 답변
That worked. Glad to see an expert that actually knows what he's talking about. Thank you!
의 답변
Thanks for the hdmi info. Learn something new every day:-)
의 답변
Thank you so much! I've been without a keyboard for over a year now. Rca sent me several replacements; some worked for a short while, some didn't work at all. Your solution did it! You are my hero!
의 답변
I have the same problems but i went to display and im not seeing anything that says hdmi
의 답변
1에 댓글 더 나타내기
의견 추가하세요
you may need to reinstall the drivers or check the docking port to make sure the docks are both clean and have no lint as this has been an issue with this 2 in 1. hope this helps
해당 답변은 도움이 되었습니까?
점수 2
댓글:
How do I reinstall the drivers. I bought a different keyboard cause mine quit working, now the new one won't work......Help......
의 답변
의견 추가하세요
Trouble shoot and reconnect the keyboard.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Chris 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 42
지난 30일: 204
전체 시간: 6,671
