Is there any way to remove striped screws from the bottom?
I have already opened my iBook before and now I can't get it open again because the screws are striped. They are torx t-8 screws. If I can't get it what are my other options?
좋은 질문 입니까?
좋은 질문 입니까?
Here's a link to an excellent answer by a top technician: What are your tips/tricks for removing or extracting stripped screws?
If this works for you please upvote HIS answer. Thanks
해당 답변은 도움이 되었습니까?
Good link +
Do you mean the threads are stripped?
If so, you could try putting a little blob of something sticky (like bluetac?) into the head of the screw then put the torx driver in and as you unscrew try to gently pull the bolt out at the same time.
HTH
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 986
