주요 콘텐츠로 건너뛰기
Model A1224 / Mid 2007 및 Early 2008 / 2, 2.4, 또는 2.66 GHz Core 2 Duo 프로세서
542 질문 전체 보기
imac not starting up even in safe boot mode...the apple hardware test
results were error code
1st pass 4MOT/1/40000003:HDD1404
2nd pass 4MOT/1/40000003:HDD1409
Please help.We purchased the computer in Singapore and it was working fine until after we shipped it over to Toronto where we are now.Appreciate any help.
Thank you so much.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 4개
선택된 해법
I know it's old but others may find it useful.
I believe the error relates to the HDD fan not spinning up to the required speed
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
댓글 달기
가장 유용한 답변
I concur - those AHT codes refer to the Hard Drive/Hard Drive controller. It could be as simple as the connector working loose in transit.
If you are near an Apple Store or AASP, take it in and have them run Apple Service Diagnostics - it is more comprehensive and should help pinpoint the failed subsystem. (ASD is not available to the public.)
해당 답변은 도움이 되었습니까?
점수 1
2 댓글:
correction: not available "legally" to the public.
For Canada you can find a store via this link that may also repair: http://www.apple.com/ca/buy/locator/
댓글 달기
Looks like you need a new hard drive get one here. If you need to recover data I suggest Data Rescue 3, it actually works, I've used it to recover data myself.
해당 답변은 도움이 되었습니까?
점수 0
2 댓글:
Careful with data recovery software on a failing drive. It can make the problem of getting the data more difficult and costly if it doesn't work. These programs put the drive through vigorous use. Like taking your grandma for a marathon run...
Not really actually, it's not that expensive and you usually only need to run it once. Obviously it's not gonna be good if you do it 30 times, but you only need to do it once or twice. That is why trying to clone the drive first is good.
댓글 달기
'cause that's what the service manual tells me... there is no reference to the following number but I believe it is the actual speed detected at time of error.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
obstructivism 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,859
