91 camry dx wagon Blew fuze, what else?
Today I needed a jump for the old dead battery on my 91 camry 4cyl wagon with 212000 miles. I accidentally put negative on positive & positive on negative on my mom's car battery AFTER putting the cables in the correct places on my car, it did spark a bit & I turned them around right away but it blew the 80v main fuze on my camry. I replaced the fuse and put in a new battery and now the car will turn over but it won't start, what else may be wrong? Could be ignition.....for about 3-4months every 10-15th time I start the car(I drive it & run around a lot every day) it makes a weird noise when I turn the key & won't start untill the 3rd-4th try.
If it helps to know i replaced the starter when it didn't need it at 200,000 miles so not long ago, voltage regulator went out at 205,000 so replaced alternator then. is it ignition or fuel pump why it won't start? Or did my dumbass short out new alternator with them cables? I'm in thinkn it's fuel so got a fuel filter & gonna see.
좋은 질문 입니까?
댓글 3개
Your car would start even if you shorted out the alternator since you have a new battery.Double check all connections around the fuse.
oldturkey03 의
Ya I noticed one inside light not working still, thanks! Il go try now
Chris strobel 의
Fuses & wires are all good. There's no spark to the spark plugs, tested those & put some starter fluid in & nothing so I'm guessing ignitor or ignition coil but today, when giving it gas there was a weird knocking noise coming from gas tank which wasn't there yesterday.
Chris strobel 의
