주요 콘텐츠로 건너뛰기
The drone is a Wi-Fi capable and it's equipped with a built-in HD camera. It is used for taking pictures and filming. Model number: PF722000
35 질문 전체 보기
rapid power loss power dives from 100% to 3% in seconds
the power reading reduces from 100% to " critical battery power" in about 10 seconds after take off any advice . tried two new batteries same result. Charger charges back up to green within 15 mins. switch off copter and reboot shows the power at a level you would expect (80-90%) than does the same again when you you press take off. any advice ANYONE cheers
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Try a different charger and measure the battery voltage if you have a multimeter.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
colin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 8
전체 시간: 95
