주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
2013년 7월에 출시된 경제적인 Samsung Galaxy S4 버전입니다.
110 질문 전체 보기
질문 마감됨
How to Retrieve Data from a Broken Screen Samsung Phone
My cell phone (Samsung Galaxy S4) fell down from the stairs. Doesnt display anything. The phone still boots up and I am able to call my phone number with my Mum's phone.
I don't want to use my S4 any more, because I will buy a new Galaxy to replace, but I need to copy off at least my contacts, call logs, pictures/videos and WhatsApp chat history from the phone.
What's worse, the phone's screen has a lock on it. I am not sure if I had USB Debugging enabled or not.
Is there any way can help to restore my data from the screen broken Samsung phone, please help?
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 10
댓글:
Have no idea about how to recover data from broken Samsung phone like the S5/S4/S3/Note 4, Galaxy A9/A7/A5, Galaxy Grand Prime, etc.? Don't worry. It is totally possible to use a data recovery to help your output all data saved on the phone.
As we all know, contacts, messages, call logs, chat history and more are stored on Samsung internal memory and many data recovery programs can't extract the data from internal memory. But, here comes Samsung Data Recovery, a powerful program helping you to recover data both from Samsung internal memory and SD card. Contacts, messages, photos and videos are all supported to be found by the software and you can easily access them to retrieve.
Read more from: https://www.youtube.com/watch?v=5bGjZe6x...
Periodically back up your data, can effectively avoid the loss of data.
There's no response when I touch the screen. Some data that saved on the SD card is easily to deal with, we just need to plug out the SD card and put it in any other phone we like.
According to your situation, if you cannot disply the phone and the touch is not working, I suppose there is no way to recover your data in your broken phone. Or maybe you can try to download the FonePaw Android Data Recovery, and connect your broken phone with USB. Then see if it can connect to PC successfully. If it works, you can use it to recover your data to your computer.
9에 댓글 더 나타내기
의견 추가하세요
Nintendo Switch 수리 키트
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
답변 2개
가장 유용한 답변
If your Smartphone’s Screen broke up, the most easiest ways to recover your data from your smartphone is by DATA CABLE or Using Samsung KIES. Well if you didn’t backed up your data, didn’t stored it in your SD card and you didn’t even turned on the USB debugging mode and all the functions and backlights of touch buttons work but you cant see anything on the screen, and you have connected your smartphone to your Laptop from data cable but you cant access your files because the screen is locked with a security pattern and you can not unlock it because the digitizer is not working,and you have also tried KIES but Still unable to recover your data, well this post can be of your great help then; I have collected a methods that can help you recover your pictures , videos, messages and contacts from Samsung S2 S3 S4 S5 S6 Broken Screen smartphones with ease.
Read more from: https://www.youtube.com/watch?v=Rz04Fztc...
해당 답변은 도움이 되었습니까?
점수 2
댓글:
link is dead (video not available)
Ticked all the boxes in my problem but the video itself isn't available..
Whatta bummer..
Anyone can help?
You can visit this link. It has a easy way to recover data from a Broken Screen Samsung Phone.
https://www.doctor-telephone.com/contact...
If you have tried plenty of methods to retrieve trapped files like photos, videos, messages, WhatsApp Messages, contacts and more other data in a Samsung Galaxy phone or tablet that is out of gear, maybe you will find a satisfactory outcome after turning to FORecovery Android Broken Data Recovery.
https://www.forecovery.com/samsung/recov...
If your Samsung phone screen is broken and the touch doesn't work, you can try downloading Broken Android Data Recovery and connecting the phone to your computer with USB and see if it works. If it is possible and the model is a supported model, you can export the content to your computer. https://goo.gl/T8Kxo1
의견 추가하세요
Samsung Galaxy Recovery and Samsung Recovery for Mac can helps to fix your Samsung stucking into blank screen/recovery mode, and repair a bricked with a click, and restore your data from broken Sasmung with ease.
For Example: Recover Data from Samsung With Broken/Cracked Screen
Read more from: https://www.youtube.com/watch?v=gfrpbfqz...
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Want to get data back from your broken,damaged phone?You can install a broken Android data recovery on your computer Mac or Windows,then connect your phone to PC. It will automatically scan for the lost data and show the recoverable data. However,you can recover photos from broken Samsung phone,please learn the use guide as below:
http://www.android-iphone-recovery.com/r...
In additional,if you phone was damaged with water,you also can use this program to Recover Data from Samsung Galaxy S5/S4/S3 with Water Damaged
Here's a tutorial on restoring SMS from a Broken Screen Samsung Phone. I found that it can also restore music / contacts / photos. I hope it can help you.
Read More: How to Recover Text Messages from a Broken Samsung Phone
의견 추가하세요
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 291,360
