주요 콘텐츠로 건너뛰기
Repair guides and troubleshooting support for Leapfrog LeapPad3 Learning Tablet
Why isn't my device turning on?
I've held down the power button and it isn't turning on, no matter how long I hold the button down for.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 1개
Hey, my 4 year old sister LeapsterGS won't turn on. I've tried doing new batteries it still won't work can you please help or do you know something about it??? AND, I've lost the charger that came with it... Thanks!
댓글 달기
답변 3개
선택된 해법
I'd start by making sure the battery is charged. Try plugging it in using the adapter and cord. Be sure that you double check the connections between the adapter and the wall and the cord and the device. Make sure that they are both connected securely or the device will not charge and this is a common mistake.
If the LeapPad still won't turn on, it could be that the battery is dead. At that point in time, all you can do is replace the battery.
It could also be a malfunction with the power button or an issue with the software, but I'd make sure it's not the battery before anything else.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
How old is it? Is it still under warranty. Are you sure the battery is charged up? Do you get anything on the screen? http://www.leapfrog.com/en-us/legal/warr...
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Try New Batteries!
Or charge it with the charger that came with it!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
David Saso 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 31
지난 30일: 147
전체 시간: 15,881
