Backlight/ LCD faulty? Help!
Hello my friends,
after "just Glass Repair" Backlight or LCD faulty?
Someone know?
If it´s just Backlight i think i can fix it but LCD that would be horrible.. :(
Here pictures with black and white background..
Thank you so much for your help!
I hope that someone know it!
좋은 질문 입니까?
No water damage.
The Glass cracked so i tried just to repair the glass without replacing the hole Display Assembly.. i used this Tutorial https://www.youtube.com/watch?v=w8cZ5YLM...
Yes i think there is some fluid on the backlight but you can see some issues ( black picture) an i don't know is this just on the backlight or is there also an damage on the LCD..
Christian Wolfram 의
Backlight problem.
Bing 의
But why is the damage on the black/white background different?
Christian Wolfram 의
I tried to click on the video you provided. but for some reason it wont play. so idk what steps you took to replace the glass. But did you use LOCA to replace that screen? it seems like a backlight damage that couldve linked to a LOCA repair.
Bing 의
I used an hairdryer to heat up the glass and used playcards to separate the LCD from the glass.
No LOKA or any other glue, just some isopropanol to the clean the LCD.
5 h work...
Christian Wolfram 의
댓글 6개 더보기
