주요 콘텐츠로 건너뛰기
2014년 7월 28일에 출시된 Samsung Galaxy S5 mini는 8MP 후면 카메라, 720p 화면, 지문 스캐너 및 방수 기능이 있는 휴대 전화입니다. 이 휴대폰은 이전 모델 Galaxy S5에서 개선된 더 큰 화면, 늘어난 배터리 수명 및 카메라가 있습니다.
30 질문 전체 보기
S5 Mini Screen issue "Shows static"
Hello,
I just replaced the entire Lcd/Glass/touchpanel with a new kit. Everything went fine until I switched on the device. Everything seems to be working OK :
- Phone starts up
- Welcome sound
- Is recognized and reachable via USB connected to PC
However the screen does not function correctly. It is like static on an old TV set. (See picture) I tried several times to gently press on the screen connector and such but no difference. Any ideas ? Many thanks for your help !
Tony
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Had this issue once with a HTC One M8 new screen. Turns out it was faulty. Luckily your phone isn't damaged as this has also appeared on a Samsung Galaxy S3 when it's charger port was changed using the heatgun method.
Almost certain the screen is at fault as the phone still functions, just the screen not working.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Hello Ben, thanks for the reply. That is what I suspect as well. However I saw some other posts on internet saying it was a badly attached connector. I repetedly removed and inserted the one but same result so yes probably the display is faulty.
Kind Regards,
Tony
πως το διορθωνουμε αυτο το ποβλημα?
댓글 달기
it could be the screen.. but i also had issue with one.. the fault rather tends to be a software issue... i was brought back to normal by flashing (not factory reset).
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
how do i fix this problem?
by flashing it with Odin
댓글 달기
귀하의 답변을 추가하세요
tonyknors 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 1,742
